Reply
Highlighted
Follower
Enable UPnP
I am trying to turn on the UPnP on my Nighthawk X6S AC4000.  I log into the routiner's network, go into Advanced settings then Advanced Setup but the UPnP option is ghosted.  I even typed in the web address shown when I hover over the ghosted UPnP (www.routerlogin.net/UPnP_upnp.htm) with no luck.  Please help!  My we cannut use the wife with our XBox One without enabling the UPnP.  Thank you in advance!
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
Highlighted
Guru
Re: Enable UPnP
   Is that accurate?  Firmware version?  Connected to what?
> [...] the UPnP option is ghosted. [...]
   Is anything else?
      https://kb.netgear.com/26765/
   If the R8000P is configured as a wireless access point, then UPnP
would be configured on the main/only router, not on the R8000P-as-WAP.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 290 views
  • 0 kudos
  • 2 in conversation
Announcements
