- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Enabled Vlan tag and broke WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to solve this issue by holding the reset button for 30 seconds,removing power source and continuing to hold reset button for 30 seconds, then plugged power back in while holding for 30 more seconds. All the lights went off and I just had a blinking power light, I power cycled the modem and then I was able to access the router login page.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Enabled Vlan tag and broke WiFi
> Model: R6700|Nighthawk AC1750 Smart WiFi Router
Is that accurate? Not R6700v2 or R6700v3? Look at the product
label. Firmware version?
> [...] advanced settings [...] Any way to fix this?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Factory
Settings" (or "reset").
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
