Reply
Highlighted
Enabling Ports on R8000
I just bought an R8000. I have two devices that can't get an IP now. A Verizon network extender and a Cisco IP phone. I think it has something to do with certain ports needing enabled. Verizon suggests making sure that 500, 4500, 53, and 52428 are open. Not sure what the Cisco phone needs. I am not sure how to do this. Can someone help? TIA
Message 1 of 4
Highlighted
Re: Enabling Ports on R8000
Hello? Anyone?
Message 2 of 4
Highlighted
Virtuoso
Here is the link on how to configure the Port Forwarding:
http://kb.netgear.com/app/answers/detail/a_id/24046
Message 3 of 4
Highlighted
Mentor
Focus on the problem - if the two devices have no ip address futzing around opening ports is not going to make a difference. Why are the devices not getting an ip address? How do you know they are not getting an ip address? How do they/should they get an ip address? Where should they get an ip address from? A very common problem when a router is replaced is a possible change in the ip address range - some routers use the 192.168.0.x, others use 192.168.1.x - if the devices were previously configured with static addresses and the address ranges change, they may appear to have no ip address.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2176 views
  • 0 kudos
  • 3 in conversation
Announcements
