Reply
Enabling/disabling airtime fairness on AC1900 R7000
AddisonDeWitt
I'm having some Sonos problems, and their support recommended disabling airtime fairness. But when I open the Netgear Genie, I don't see any option for doing so. I have the latest firmware (1.0.9.64) and the 2.4.60 version of Genie. I also looked for a newer version of Genie but all I can find is the app for iPhone, which I downloaded but also doesn't have any airtime fairness option. Thanks.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
JoseAndres041
Luminary
Re: Enabling/disabling airtime fairness on AC1900 R7000
I don't have an R7000 but I think Airtime Fairness is under Advanced Setup -> Wireless Settings.
Message 2 of 4
IrvSp
Master
Mobile Genie doesn't have all the full control of settings.
Use the Safari Browser to access the GUI Genie on the router, then as described above, you can get to it.
Message 3 of 4
AddisonDeWitt
Thanks very much for the advice.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3702 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
