Reply
Enabling guest network on 2.4/5 GHz disables main 2.4/5 GHz band
DreadLordDread
Follower
Hi all!
I run into an issue when I am enabling guest network on one of the band 2.4/5 GHz my main network goes down on the relative band.
Yesterday, I managed to have somehow 2.4/5 GHz bands on my main network and 2.4 GHz guest band for guests. But now when I try to disable SSID broadcasting on a guest network, it disables my main 2.4 GHz band again.
Just want to know if any of you encountered the same issue, or this issue is only applicable to my router.
I think a can do the trick again, but it doesn’t feel to me right such routers behaviour. I didn’t have such problems with my previous routers.
Router firmware is V1.0.0.124
Thank you!
Best regards,
Dmitry
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 137 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
