Reply
Error Message When Resetting Password for Nighthawk X6S
tutucarla
I got an email telling me to update the softward on the router.  I tried to log-in on my iPhone to do that (following the instructions sent to me), but it wouldn't accept my password.  I requested to reset my password and received an email with a link to do that.  But each time I try to reset the password, I get an error message telling me "Somehting went wrong; contact support."  But my 90-day warranty period expires last week, so I can't contact support.  But I can't update my password without doing that . . .  Seems like a catch 22.  The on-line password reset link doesn't work, but I can't contact anyone to have that problem fixed.  NOW WHAT????
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 3
microchip8
Master
Re: Error Message When Resetting Password for Nighthawk X6S
don't use Apps, smartphones or wifi to update firmware. These are unreliable tools. Go to the Web GUI  at http://192.168.1.1 using a wired connection and login with your pass. Then go to Advanced and update the firmware
if you don't remember your password and since you tried to recover it, a factory reset will do it. There's a reset hole at the back of the router
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 3
tutucarla
Thanks for the information.  Strange that the instructions that come with the email notifying me that an update is available say to log in from a mobile device and update it there.  I will follow your instructions next time!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 339 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
