Orbi WiFi 7 RBE973
Reply
Error log messages in netgear ready share vault
pricerp5
I am receiving the following Windows error log message. Can anyone please tell me what it is referring to?
Nighthawk X8 , AC5300 Triband Router,  model R8500, Firmware ver. 10.0.2.86 running on Windows 10.
Activation context generation failed for "c:\program files\netgear\readyshare vault\x86\GenieTimeLineAgent.exe".Error in manifest or policy file "" on line . A component version required by the application conflicts with another component version already active. Conflicting components are:. Component 1: C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_42191651c6827bb3.manifest. Component 2: C:\WINDOWS\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_89c64d28dafea4b9.manifest.
Thanks in advance!  Rick
Message 1 of 5
Accepted Solutions
pricerp5
Re: Error log messages in netgear ready share vault
I uninstalled and reinstalled and have come to the conclusion I did not follow the right set up proceedures when first installing the software.  It's back to the manuals for now.  I truly appreciate all your help.  Thank you!!Smiley Happy
Message 5 of 5
All Replies
ElaineM
NETGEAR Employee Retired
Welcome to the community, @pricerp5
When do you get the error?
Can you provide me the steps and will try to replicate this on my end?
Message 2 of 5
pricerp5
There is no no noticeable error.  I found this error when going through my desktops error log file.  It repeatedly occurs approximately every 4 minutes as though my computer was tryiong to connect to ready share or ready share was trying to connect to my computer.  I am running a Windows 10, 64bit system on a Lenovo A740 all in one
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 3 of 5
ElaineM
Try to uninstall the ReadySHARE Vault software and observe if it will still show the same error.
Then reinstall it.
Message 4 of 5
pricerp5
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3530 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
