Reply
Ethernet Ports not functioning well (R7000)
Luisg3324
Follower
I have my Xbox One hooked up via Ethernet to my Nighthawk. I go ahead and run a detailed network statistics test and it works fine at my usual 30MBPS with low latency. After a couple minutes I would run the tests again and it's back to around 2MBPS. This creates tremendous lag and I don't know why the speed keeps dropping especially since I'm the only one using the internet while performing these tests. I tried to run QoS for upstream to improve gaming but it got worse. Please help, I'm really disappointed that my old Xfinity Gateway Modem/Router had better ethernet connection.
Message 1 of 2
JamesGL
Master
Re: Ethernet Ports not functioning well (R7000)
Hi Luisg3324,
Disabled QoS. Do a speedtest using a computer and check if the connection degrades.
JamesGL
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1975 views
  • 0 kudos
  • 2 in conversation
Announcements
