Reply
Ethernet doesn't have a valid ip configuration
zookeee1
Moved stuff around and cleaned up office. Plugged everything back in, but now Windows says...'"Ethernet" doesn't have a valid ip configuration'. Been looking for answers on how to fix it, but the "fixes" I found don't work.  Wifi does work and I can access the router (still can't see connected devices and the "fixes" given for that don't work either), but I'm wondering if it is because I assigned a fixed ip address in the router for this computer. However, as you can see, NONE of my "wired" devices are connecting.  Grrr....
And yes, I've rebooted modem, router, computer, etc a number of times.
Anyone have any suggestions?
Below are some screenshots of computer information:
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 4
Re: Ethernet doesn't have a valid ip configuration
Run the Windiows 10 network troubleshooter?
Reset the network adapter in Windows?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
zookeee1
Yes and yes. I actually reset router to factory settings and am redoing settings (from screenshots, I didn't want to just load the backup in case that was the issue).
Now windows says it doesn't know what is wrong. I even tried what windows said to do as a last resort which was ipconfig/release then ipconfig/renew.
Nothing still
Since NONE of my wired devices are showing up, I'm now researching that problem.  Hopefully there will be a fix there. Any suggestions while I'm looking, feel free to respond......
Message 3 of 4
antinode
Guru
> configuration'.
   The simplest explanation would be that things are now not connected
properly.  "Plugged everything back in" does not say what is connected
to what.  I see more "Wired" devices than there are Ethernet ports on an
R9000.  An equipment inventory might be helpful, as part of the
connection list.  (N-port Ethernet switch?)
> [...] as you can see [...]
   I'm not absolutely sure what I'm looking at.  (1) Access Control
(showing only wireless devices)?  (2) Complete mystery?  (3) Windows
info.  (4) LAN Setup?
   I'd probably start by pulling all the Ethernet cables out of the
R9000 LAN ports, and connecting one (previously working) Windows system
to one of those ports.  If that works, then the router's probably ok,
and I'd try adding equipment (in some rational way) to that working
configuration.  If not, then output from an "ipconfig" command (Windows
Command Prompt (CMD.EXE) window) might be interesting.
> don't work.
   Not a very useful description of anything.
> Since NONE of my wired devices are showing up, [...]
   Fairly reeks of wiring problem.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 6603 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
