Reply
chopperbobby
Ethernet port on AC 750
 What is the purpose of the Ethernet port on my AC750/EX3700 range entender?
Message 1 of 6
antinode
Guru
Re: Ethernet port on AC 750
> What is the purpose of the Ethernet port [...]
   Here's an even greater mystery: What's the purpose of publishing
User Manuals for these devices if no one ever looks at them?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get some.  Read.
Message 2 of 6
Two possibilities:
  • So that you can use the range extender in "access point" (AP) mode wired back to your router
  • So that you can plug in a wired Ethernet device so that it can use the wifi to connect to your router
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 6
chopperbobby
 I did go to the Net Gear link before I posted this question, but could not find a specific answer.
Message 4 of 6
chopperbobby
@michaelkenward wrote:
Two possibilities:
 Thanks for the reply.
Message 5 of 6
chopperbobby
  My question was just to satisiy my curiousity. I could just assume that I just plugged in the router to the extender and that would be it. But, I wanted to make sure.
  BYW Thank you for the reply.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 137 views
  • 0 kudos
  • 3 in conversation
Announcements
