Reply
Ethernet ports not working
legions
Follower
Router turns on and 2.4 and 5 lights turn on but lights for ethernet ports do not light on even if they are connected to a computer. Trying to fixgure out if device is not working properly or if i need to fix some settings.
Message 1 of 2
Fairytail
Virtuoso
Re: Ethernet ports not working
Here are my suggestions:
1. use a different ethernet cable
2. Connect a different device through ethernet
3. Check the IP address of your computer
4. If its getting valid IP like 192.168.1.x then reset the router to factory default
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3088 views
  • 1 kudo
  • 2 in conversation
Announcements
