Reply
Express VPN on D7000?
Hi all,
Express VPN have a few tutorials online for using Netgear with Express VPN:
I've been able to name the server using the DNS walkthrough, however this offers limited security. I'd ideally like to install the VPN router-side so my big question is, will my D7000 support the firmware, which is supported by some netgear routers but not all (namely the R7000)?
Is the firmware the same? Will I brick my machine by installing it?
Any answers or guidance will be really useful as Express VPN have been hopeless in helping.
Thanks in advance,
Timmeh.
Message 1 of 3
antinode
Guru
Re: Express VPN on D7000?
> [...] will my D7000 support the firmware, which is supported by some
> Is the firmware the same? [...]
   Is R7000 firmware the same as D7000 firmware?  No.  (The file names
alone offer a hint.)
> [...] Will I brick my machine by installing it?
   If you could find a way to install mismatched firmware, then you
could probably use the same method to install proper firmware (after you
discover that the wrong firmware doesn't work).
Message 2 of 3
Rusty79
Hi Timmeh
Did you get anywhere with installing ExpressVPN? I'm in the same situation...
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2670 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
