Magat
Apr 14, 2022Follower
Extender with a cellular modem
Hello,
My extender was working fine with a classical router. Now I have some hard time trying to use it with a cellular SIM card router. Is it possible ? The nighthawk app doesn't see the extender
Thanks for your help.
1 Reply
try factory resetting the extender and setting it up using the installation assistant.
