Orbi WiFi 7 RBE973
Reply
Extending Wifi range R8000 with R7000
I'm a proud owner of the R7000 and Arlo Q (used as babycam).
The R7000 is placed behind the VDSL router (4x UTP) of my ISP as AP. The wireless function of the VDSL router is off.
Because the Arlo Q is able to connect well to the R7000 because of walls/range, I bought a R8000 to see
if it could solve the problem. Besides that, we're having more and more wireless devices around the house, so a upgrade is needed.
Unfortunately the R8000 is covering the range to the Arlo Q on the second floor.
Is it possible to setup the R7000 to extend the range of the R8000 on the second (and third) floor without using any cable?
Network Setup:
ISP Router ----------- R7000 AP -------- 10 Wireless devices
                  ----------- TV Box
                  ----------- TV Box
                  ----------- NAS
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: Extending Wifi range R8000 with R7000
Yes - with the R7000 configured to a pure wireless access point only, and connecting a LAN interface to a LAN interface of the R8000 (by powerline or a direct cable).
Message 4 of 4
All Replies
LeeH
Prodigy
You might have luck using powerline adapters.  I've used them for years.
http://www.netgear.com/home/products/networking/powerline/PLP1200.aspx?cid=wmt_netgear_organic
Message 2 of 4
Setting it up like this?
ISP Router ----------- R8000 (AP 1st Floor) ---- PWL ---- R7000 (AP 2nd Floor) ---- X Wireless devices
                  ----------- TV Box (1st Floor)
                  ----------- TV Box (2nd Floor)
                  ----------- NAS  (1st Floor)
Message 3 of 4
schumaku
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5167 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
