Orbi WiFi 7 RBE973
Reply
Extending mesh network with multiple
JFKone
Follower
I have a large property and I am trying to extend my network. My base unit is the R7000P/ AC2300. I have three (3) mesh extenders X6S/EX8000. Via Wi-Fi can I connect the EX8000’s to each other or do they all have to connect back to the base unit (hub)? If I can connect to each other what is the procedure? If it has to be back to the hub what is the best way to configure so I have one network login, SSID. As a novice looking for expert help. Thank you.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO,R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Extending mesh network with multiple
you want to connect them to the base unit or you could have stability issues in your network.
DarrenM
Message 2 of 2
All Replies
DarrenM
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1805 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
