Reply
Extending my Nighthawk R7000P range
TroyM88
Follower
I'm currently usign the Nighthawk R7000P and I need to extend the range to cover my entire home inlcuding my basement.  I'd like to go to a WiFi Mesh if possible.   I'd rather not scrap my Nighthawk router but will if that makes the most sense.   What are my best options?  I do have an ethernet cable available to help cover the basement, but the router is still lacking in other parts of the home as well.  Can I add some satellites to my R7000P or is it best to scrap it and go to an Orbi system?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Guru
Re: Extending my Nighthawk R7000P range
It depends.
How big is your home?
what are the interior walls made of?
do you think you'll need more than 1 extender?
If so, I'd skip the headache of extenders and go with a triband mesh setup.
If you think 1 extender would cover fine, then a triband extender would be ideal.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
You cannot add satellites if you want a Mesh system, but you can do what I do which is to use the R7000P in front of an Orbi router in access point mode.
I keep my router (an R7800 in my case) because it is more capable as a router than the Orbi, which is better on the wifi front.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 176 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
