- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extending network with hard wire extension - what is best router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Existing set up is Nighthawk AC3200 plus Netgear x6 AC2200 extender model EX7700. All owkrs well and great coverage in the house. now looking to put in a hardwire extension to garage (due to distance from house). We have wirelss security camera plus wired solar panel data to connect. What is best router to use for this to best go with current system?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not a router per se. A switch will add (Gigabit) Ethernet ports, a wireless access point will add WiFi coverage. I'd prefer this way instead of using a consumer router which makes a bad anything.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extending network with hard wire extension - what is best router?
Thanks and sounds good. What product(s) do you recommend for this (as you can probably tell i don't know much beyond basics and easy to get the wrong thing).
- Mark as New
- Bookmark
- Subscribe
- Permalink
For a switch, any unmanaged ProSafe NETGEAR one will do the job. Can't recommend an AP since I don't use them
