Reply
Highlighted
Follower
Facetime connection drop
When using R7000 + Facetime on my iPad Air, I keep losing the connection As long as I am near the router (within a couple of meters) I can use Facetime for hours without losing the connection. However, if I go >7-8 meters away from the router I start losing Facetime connection every couple of minutes. This is extremely annoying.
It makes me sad because my old WRT160n was slow but I never had issuse with Facetime connection dropping. I tried the 2.4GHz and 5GHz band and both give me the same result.
Any idea what else I could try to fix this issue?
Message 1 of 3
Highlighted
Retired_Member
Not applicable
Re: Facetime connection drop
You might try a factory default reset and use the default settings other than WIFI and security and try again.
Use facetime all the time without a problem on iPadAir 2.4 or 5g no issue.
Message 2 of 3
Highlighted
Virtuoso
Since it works at short distance but not after you move away then uou may want to look into adjust antenna
Not sure you are using far away from router on the same floor or upper/lower floor
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2162 views
  • 0 kudos
  • 3 in conversation
Announcements
