Orbi WiFi 7 RBE973
Reply
Factory reset issues RAX43
MJC314
Follower
Can't seem to get the factory reset done correctly. I have the app and when I choose the WiFi, it asked for the password and I continue to get "incorrect password" message. Help!
Message 1 of 2
Guru
Re: Factory reset issues RAX43
Have you tried hardwiring a pc/laptop into it?
Then you can go through setup and check/change the wireless ssid/password and it skips having to know them for setup.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 371 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
