Reply
Failure/Spotty Wireless Network (5GHz 802.11a/n/ac)
VFk
Spotty wireless network 5GHZ after firmare update to V1.0.2.32 connetected devices that oonce had good signal nolonger able to stay connceted. Only on the 5GHz side 2.4Ghz seems to be OK.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
William10a
Master
Re: Failure/Spotty Wireless Network (5GHz 802.11a/n/ac)
Have you tried a reset of the router if you belieive that is the firmware you could downgrade the firmware by apply the older version of the firmware and see what happens.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2265 views
  • 0 kudos
  • 2 in conversation
Announcements
