- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Feedback for R7000 New firmware 1.0.9.18
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Feedback for R7000 New firmware 1.0.9.18
I was having 5ghz disconnects daily with firmware 1.0.9.18. I turned off the 5ghz guest network and every single problem disappeared. Just wondering if anyone can attest to the stability of 1.0.9.26?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@LM22wrote:I was having 5ghz disconnects daily with firmware 1.0.9.18. I turned off the 5ghz guest network and every single problem disappeared. Just wondering if anyone can attest to the stability of 1.0.9.26?
You and me both. I noticed the beta was pulled a while back. Haven't seen anyone mention results after installing the final release.
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
i´m on 1.0.9.26 and having absolutley no problems, 11 days up without reboot.
wifi: 2 samsung tv´s, android tablet and mobile, raspberry pi - all on 2,4 ghz, win10 laptop (5 ghz)
lan: dlink nas, 2 raspberrys, denon network av receiver
guest wifi 2,4 ghz activated for guests
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I had to roll back to 1.0.9.18 because 26 completely broke my 5Ghz network for my lightswitch and on my iPad made the speed go from 50Mbps to 5Mbps. Downgrade fixed all. 2.4Ghz was unaffected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Upgraded to 1.09.26 on the 18th (little irony there). Upgrade smooth, router rebooted on it's own. Came back online with no fuss. As far as I can tell, all my previous settings remain. Both 2.4 and 5Ghz bands are turned on as it was prior to the upgrade.
No connections issues or drops. No lag or buffering, even with 3 devices simultaneously playing 1080P youtube videos.
Have devices hardwired to the R7000 and none of those exhibit any connectivity issues. I do not have any Google/android devices. Wifi connected devices run Linux Mint, Windows and iOS.
Looking good so far.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi All,
We have recently released a hot fix for the R7000 WiFi disconnect issue that has been reported.
Release Notes
Bug Fixes:
· Fixes the Wi-Fi disconnect issue caused by a flood of broadcast traffic.
· Fixes security issues.
To Install
Note: To avoid wireless disconnect issue during the firmware download process, NETGEAR recommends that firmware upgrade be performed on a computer with wired connection.
1. Write down all the settings which you changed from the default values, since you may need to re-enter them manually.
2. Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop. The filename after extracting is R7000-V1.0.9.26_10.2.31.chk
Download Link:http://www.downloads.netgear.com/files/GDC/R7000/R7000-V1.0.9.26_10.2.31.zip
3. Log in to the router using a Web browser. The URL is http://www.routerlogin.net.
4. Click ADVANCED tab > Administration > Firmware Upgrade.
5. Click Browse and find the file you just downloaded.
6. Click Upload. Do not interrupt the upgrade while the router does this step.
Important Note:
The upgrade process is completed when the on screen progress bar completes.
If the upgrade progress bar on web GUI doesn’t display correctly during firmware upgrade, you can still check the status using Power LED. The Power LED should be blinking (amber) during firmware upgrade. After firmware upgrade is done and boots up the system, it changes to steady amber color.
Please DO NOT power off or reboot the device during firmware upgrade, otherwise, it may result to a corrupt firmware and cause the device not to work.
If this firmware update resolves the issue(s) you have been experiencing we would appreciate your update to this thread. However, if you continue to encounter WiFi disconnect issues or any other unexpected behavior please open a new topic.
Subject:
R7000 FW: 1.0.9.26 - <Include a specific description that best summarizes the issue being reported>
Body of the Post:
· Include Device model Number
· Current Firmware version installed
· What error message(s) or unexpected behavior you are encountering
· Whether or not the issue exist prior to the firmware update
· Steps to replicate the issue
· What troubleshooting steps have already been taken
· Client used (iOS, Android, Web) and client versions/OS versions
· Please do NOT include any personal information such as address, phone number, serial number, social security number, credit card number, etc.
We look forward to your feedback.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I wanted to put time limits on when the internet is turned on. This led me to realizing that the date and time on the router is wrong and cannot be corrected!
I have the correct time zone. Even changing the time zone does not change the time.
I looked at past threads and this seems to be a recurrent problem with netgear routers. I have the most recent firmware installed
V1.0.9.26_10.2.31
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I see where the confusion came from now. At least what threw me anyway... The link on the right is now dead. This was the last hotfix, or so I thought. Then 1.0.9.26 was put on the download page but it was the same file. It appears that the name was appended, but its the same _10.2.31.zip. So for people that asked if it was the same file as the one which was released earlier, I say yes.
So as of 2/13, Netgear is considering the issue resolved with the caveat from James.. "please let us know if you are still having issues".
I'm going to try it this weekend and see how it goes.
Cheers
~EX3700 FW:1.0.0.84
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Yugiohwrote:I wanted to put time limits on when the internet is turned on. This led me to realizing that the date and time on the router is wrong and cannot be corrected!
V1.0.9.26_10.2.31
I have 3 Netgear products currently in use and am not having any issues with time. I believe (not confirmed) that the router gets its time from an NTP server... what do you have in front of your R7000? Have you confirmed its time? Maybe its blocking the routers ability to communicate?
~EX3700 FW:1.0.0.84
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you guys for the recommendation for XWRT-Vortex firmware! I've been struggling for at least a month with my R7000 and slow internet. It's used in a medical practice and our medical records software would sometimes time out, and it was getting really frustrating. Ever since I installed Vortex, i've had zero issues. It's literally like a brand new router.
It really sounds like Netgear needs to hire a new software team. I had the Orbi a year ago and had nothing but issues with buggy firmware. I don't get what's so hard about quality testing your software before release
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I entered an NTP address and it works now.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I started using the Circle with Disney about 6 days ago. Now I am having connetion problems on my iPhone. I lost my 5GHz. I had 2 laptops using that channel. Since I started using the Circle with Disney, the 5GHz is on channel 153. The laptops cannot find the 5GHz anymore.
Now I might just flash with XWRT-Vortex.
When is NetGear going to fix this problem???
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Updated from 1.0.7_1.1.99 > 1.0.9.26_10.2.31
Current bandwidth 300 / 12 (comcast)
Verdict: Immediately lost 50% of my downstream bandwidth
I went through every single page and menu. I went into QoS and enabled it, downloaded the newest definitions file (dated 7/23/17) -For Christ sakes Netgear- saved and rebooted. Still at 50% of previous downstream bandwidth. Disabled QoS / WMM all together and rebooted, no change.
I then tried manually defining bandwidth, saving, rebooting and testing after each change. Rebooted the cable modem as well, multiple times with the same results. Best I could get was 165 down. The speed test in the router said 214 down, but I never saw that.
Then I reset the router to defaults... just tested wired bandwidth. SAME results, only 50% of previous downstream bandwidth.
ok... Let's be extra thorough.. reflash 1.0.9.26... which blows away the downloaded QoS configuration whether you have it enabled or disabled.... now its back to being blank - SAME results (50% of downstream).
***Connect directly to cable modem - get 300 / 12
Have about 43 minutes invested into this "upgrade" now. Have restarted at least 20 times.
Next step. flash back to 1.0.7... reapply config file. Retest downstream / upstream bandwidth.
Your result may vary. I never bothered checking wireless device performance as wired performance is paramount for my work. Sticking with 1.0.7.. for the foreseeable future. Don't have the time to mess with this.
Observations:
I have seen QoS wreak havoc on previous versions of FW, but have always been able to overcome them by disabling it and WMM. Not this time.
This is the page you are greeted with after upgrade. No I don't want automatic upgrade from a stable FW release and no, gather your own telemetry data Netgear.
Next, parental controls. Big no to these as well.
And finally the QoS update. Tested with and without. No difference.
~EX3700 FW:1.0.0.84
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It appears that i have problems with streaming movies via my network with this router..
I have 500/500 MB/s Internet and i connected my Sony Smart TV 4K via network cable and i get constant stutters or buffering lag while streaming 4K movies. anyone knows what can cause this or what the bottleneck is in this case?
Thnx in advanced.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Intentionally deleted.
~EX3700 FW:1.0.0.84
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Case850wrote:
If you have a Android phone can you install the following Android and post screenshot of 2.4G & 5G channels.
https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en
Have iPhone 6s
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@mixolydwrote:Thank you guys for the recommendation for XWRT-Vortex firmware! I've been struggling for at least a month with my R7000 and slow internet. It's used in a medical practice and our medical records software would sometimes time out, and it was getting really frustrating. Ever since I installed Vortex, i've had zero issues. It's literally like a brand new router.
I lost my 5GHz when I installed/tried to us Circle with Disney. Do you have the 5GHz?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@rogier64wrote:Flashing XWRT-Vortex is simple. Flash it just as you would flash NG firmware. In the download package you will find 2 firmware files as well as some info text files. If you are on NG firmware you must use the .chk firmware file, if you are on XWRT firmware (future upgrading) you must use the .trx firmware file. That said, you cannot easily revert to NG stock firmware as NG doesn't use .trx files. There is however an old NG firmware package available ported to a .trx file. But don't worry, once you are on XWRT you won't go back. On the other hand, why flashing 3th party firmware if you don't have issues with stock firmware.
I have 4 grandkids that we are guardians of & wife & I wanted some control (parental control) on the network(phones & computers). So I installed Circle with Disney on NetGear. What a bad idea that was. Was working good until I tried to use internet on the Samsung Smart TV. No 5GHz. Then I checked 2 laptops that was using 5GHz. No 5GHz either. Uninstalled Circle with Disney hoping to get 5GHz back. No luck there. Rebooted a number of times & that has not worked. Now I am going to do a hard reset & find out if I get 5GHz back.
Now I am pondering if I should just go to XWRT-Vortex.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@AlpineKid66 XWRT-Vortex is based on Asus WRT and they have AiProtection as parental control. But I'm not sure it will work as it is not an Asus Router. You can however do some parental control by using certain DNS servers like OpenDNS for filtering web content. Not sure if that's what you're looking for.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@rogier64wrote:@AlpineKid66XWRT-Vortex is based on Asus WRT and they have AiProtection as parental control. But I'm not sure it will work as it is not an Asus Router. You can however do some parental control by using certain DNS servers like OpenDNS for filtering web content. Not sure if that's what you're looking for.
If I install XWRT-Vortex, the parental controls I will have to figure out.
My question now is, if I install XWRT-Vortex, will I get my 5GHz back after uninstalling Circle with Disney?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
There shouldn't be any reason why you wouldn't get your 5GHz back. XWRT-Vortex just works. There is no Disney Circle with it so nothing for you need to uninstall. With regards to parental control, you could set up a network with access to internet on a scheduled basis, and you can manually turn off access from the admin either on your computer or install the Asus app on your smartphone/tablet (it will find the Netgear router during setup and identify it as an Asus RT-68U or something like that) and you can also control it there on demand.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@ AlpineKid66 as @ Rikardo007 has explained that you do not have to delete anything in the NG firmware. The entire user interface will be changed by flashing XWRT-Vortex. You must reconfigure your router. And yes, you get your 5 GHz back. Keep in mind that your Wi-Fi bands will be unlocked for all regions by default. There are no restrictions on Wi-Fi channels and output power. You can adjust both, but keep in mind that you can choose Wi-Fi channels that are not available in your country by default.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
For what it's worth, read this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you for info.
Currently have 14 routers out in field, i assit with.
Only 3 are working properly because Xwrt-vortex in installed on them.
Was getting calls from user, can't connect, slow, Choppy video.
Reset routers problems return, Also remote addmin very slow.
Netgear is draging ther feet on this issue & issues.
Will eventualy change all routers to Xwrt.
Can't rely on Netgear to fix a flash light.
Very disappointed with speed of resolving these issues
Even with reseting to factory default and applying all fixes, still doesnot work properly.
Also Wireless finally function and at full speed.
Noticed have Netgear wireless power was set to high to use longer distance , needed a second R7000 router set to AP mode.
Since Xwrt-Vortex wireless power set to 50% there is no need for second R7000 in AP mod.
Would like to return to Netgear firmware some time, if they can get there act together.
Anyways
just some thoughts
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
BTW Belkin bought linksys. They aren't the same company they used to be.
User | Count |
18 | |
13 | |
6 | |
4 | |
4 |
