- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Feedback for R7000 New firmware 1.0.9.18
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Feedback for R7000 New firmware 1.0.9.18
I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You should review this and maybe revert back to this recommended version of FW:
@Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK853 (Router Mode), Wired Backhaul and RBK752 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Can someone tell me what Tomato is and how to flash it plz? I want to stream movies but its not possible with this crappy firmware.. If this doesn't get solved i return this thing to the retail store and get something else that DOES work..
thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try this: http://bestwirelessroutersnow.com/dd-wrt-vs-tomato-vs-openwrt/
Remember, Google is your friend.
My setup: Comcast -> Netgear CM2050V -> Netgear R7800 (Voxel V1.0.2.96SF)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thnx for the link.
I know google is my friend, but because a lot of people in this thread are talking about tomato etc. its only logical to ask here..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Open wrt supports more devices and is more stable on a wider variety of devices including those outside netgear. However it's a lot more complicated than Tomato.
Tomato is considered the lightweight easier to use version of open wrt. It is less universally compatible however and you can still hang yourself.
They really aren't for basic computer users. You can't use Netgear genie on them. If you don't understand what the settings are on the webpage router version, tomato is not for you. And I'm not sure what kind of support you will get if you brick your device with tomato (which is a small possibility if you set up the firmware wrong)
Best of luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi
I've applied the latest 1.0.9.18 build .chk file via tftpd to revert to normal Netgear build from dd-wrt. However, whenever I browse to 192.168.1.1 the browser redirects me to http://www.routerlogin.net/genie_index.htm which of course doesn't connect as I haven't set the router up with WAN yet.
Can someone please enlighten me as to how I can get to my router settings page so I can change IP address, WiFi passwords etc? Very strange how it tries to go to the internet.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hmm ok, thanks. I have been going straight to http://192.168.1.1 and it keeps redirecting me back. I'll try setting my DNS manually to that of 192.168.1.1
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Q: Does Asus know about this project?
A: Yes. We frequently exchange emails, and they have also integrated some of the features and bug fixes from this firmware project into the stock firmware. So far they have been quite supportive of this project, for which I am very grateful.
source:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
That is not exactly true when it comes to Asuswrt-merlin...
@kiotobgwrote:Q: Does Asus know about this project?
source:
https://github.com/RMerl/asuswrt-merlin/wiki/FAQ
That is not exactly true when it comes to Asuswrt-merlin hack firmware running on non-ASUS routers. I think eventually ASUS will shut these down.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Might want to look https://community.netgear.com/t5/Nighthawk-WiFi-Routers/DD-WRT-and-other-third-party-firmware/m-p/44..., message 24... 3rd parties might not have the rights to distribute all code, so either the function would/could be missing, or the entire binary could be considered illegal possibly. Maybe 'someone' is turning a 'blind eye' on it but at some point it might be necessary to remove the firmware (if that is even possible to determine who has it?)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
They don't need to remove 3rd FW. All they need to do is make future firmware releases not functioning in non-ASUS router. Should not be that hard to check the hardware before starting up. As far as I know, some of ASUS firmware modules are not open source.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Why are we having this discussion.
If Netgear would fix there firmware , this would academic.
Get after Netgear.
For now all is working with 3rd party firmware could not wait any longer.
people 14 of them i support were starting to complain.
When and if NetGear get there head out of the ground.
then would entertain going back to there firwware.
Just a thought
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It was still 2017 when this first started....lol
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
No not been fixed by Netgear.
have moved on to third party firmware.
No issues.Router has never worked better.
Don't even know its there now, everything works and is stable.
Wireless works, no disconnects, Media streaming doesn't choke any more.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I noticed that the firmware was now on 1.0.9.26 so though everything must have been fixed by now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I took the plunge and installed Tomato and no wifi drops. Pretty simple to install. I also run some linux computers and I am now able to print from linux to the network printer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
A new firmware version is available for downloading.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You're joking. Reconfigure everything!?!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Nope, this is not needed in most cases. Nevertheless, you can make an backup of your router settings and set everything back later on new firmware.
- « Previous
- Next »
