- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Feedback for R7000 New firmware 1.0.9.18
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Feedback for R7000 New firmware 1.0.9.18
It would be great if Netgear communicated what a given version is expected to fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just update and test if your problem is fixed. Mine didn't having any issues with 2.4 GHz even with 1.0.9.14. Also you can back to previous version at any time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
.20 Hot Fix. The link is above. Page 4 for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know I can install it. I need to know whether it fixes the dropping connection issue for my own reasons. Experimentation is not an option for me right now. That's why I'm asking if someone can volunteer info on that.
What's the IPTV issue? Are all 2.4 GHz connections dropping for you on the .20 firmware, or is that a different issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That was a good suggestion.
I enabled device access control and authorized the devices.
I then again upgraded to 1.0.9.18 and no issue raised all devices work, even the Glaxy A3 that could not navigate internet at the first attempt.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will continue to report next days about this beta release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
gandmclark solution works for me. Turn on access control, and the problem of android devices got no internet fixed. I am running on version 18 now. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Installed the .20 firmware hotfix about 5 minutes ago. So far, everything is back up and running. I will give you guys an update when I can. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the .20 code still beta; I'm not seeing anything that looks like a final release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear developer do you expect a solution next day? This situation is not acceptable!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still stable on the .20 Hot Fix. Almost 3 days now. Speeds are good. Android is stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
not to happy after upgrade
after firmware V1.0.9.18_1.2.27 no android device will give internet connectivity.
did downgrade v1.0.9.14_1.2.25 works now
dowloaded from netgear
good luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having similar issues with loss of 2.4GHz. I am not running smartconnect and have seperate SSIDs with the same passwords.
About twice a day all my 2.4Ghz devices loose access to the internet. I can connect to the 5GHz via my phone and reboot the router and everything works for a few hours before I get back to the same state.
It is becoming very annoying because when I lose access my Harmony remote no longer works and it makes the wife very angry. I miss my stable firmware. I am not sure what version I was on before, but I updated via the router page and the whole thing started failing requiring a physical reboot. I upadted to 1.0.9.18 to see if it resolved the problem. Now I will have to try several older versions to get back to stable even if it means I have a security problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I will give that a try and see. Really hoping for the stability I had.
I went 4 years without any real issues and even bypass my Google Fiber router in favor of the netgear because I have been so happy with it. I figured I should update due to Krack and that is where things went wrong. I took the web page update so figured it was stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
where do you find the hotfix? I don't see it on the download page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/000053168/R7000-Firmware-Version-1-0-9-20-Hot-Fix
But I have also problem of 2.4GHz drop with this version.
Good luck
