Wuiser
Apr 07, 2021Follower
Find PIN
I switched wifi locations and am now setting back up with my home wifi. I am being asked for my PIN or my security key.
Where do I find these please? I have also tried using the WPS button.
1 Reply
- DarrenMSr. NETGEAR Moderator
It is asking for your wifi password. You will need to connect a pc to the router directly with an ethernet cord to log into the router if you have forgotten your password.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
DarrenM
