Reply
Firewall
KingProngs99
Firewall
I am currently trying to setup a minecraft server and I am trying to get my router to Portfoward. I have set it up and just wanting to check the firewall settings to make sure it is not blocking the portfoward but there doesn't seem to be a tab for it. Could someone point the firewall tab to me so I can allow it thru the firewall if it is not already.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
schumaku
Guru
Re: Firewall
Hi, is this on the Nighthawk X4S or on the XR500 as you've posted in the XR500 section?.
Kindly refer to the Nighthawk WiFi Routers area for the Nighthawk routers not using the NetDuma platform. Anyway, there are no dedicated FIrewall controls on the Nighthawk WiFi routers, any port forwarded is open automatically.
Message 2 of 4
KingProngs99
Re: Firewall
Thank you for the info, sorry for posting in the wrong subject.
Message 3 of 4
schumaku
Guru
Re: Firewall
This shold be no blame to the users. Netgear Community config does make it hard to fetch the right spot for the "normal" Nighthawk WiFi routers.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1239 views
  • 3 kudos
  • 2 in conversation
Announcements
