- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firm Ware update for N300
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to update firmware. I cannot do it now with netgear genie. I found that my ISP must perform the update. Just wanted to confirm before I contact them. Am I correct? Is there anything I need to be aware of before I contact them?
Thanks
Gerald,Rahm
geraldlr@aol.com
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
SUCCESS....I got the firmware updated.
Thank you for your help and patience,
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firm Ware update for N300
You have the wnr2000v5?
If so, the isp doesn't update it, you do.
you can get the firmware and the manual that goes over a manual update here:
WNR2000v5 | N300 WiFi Router | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I purchase support to help me upgrade firmware?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't take this the wrong way but if you truly have a wnr2000v5, its more expensive to buy support than it is to buy a new one.
Its pretty easy to update the firmware.
you can read the guide here:
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get to step 8 in the instructions:
When I enter the router admin user name and password I get an error message that the server does not support the operation requested by your client. I have tried the default address 192.168.1.1 but that does not work either.
Any ideas how I get around that?
I appreciate your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
step 8 is the password/login info for the router.
Does the password/login info screen pull up?
But when you enter the password info, it says not supported?
Did you change the password?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I didn't change the password. I am using the defaults.
I did run across something. I might need to clear the cashe in the firefox browser.
That might take me a little time to figure out.
I will get back with you. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I need to stop working on this for a while.
- Mark as New
- Bookmark
- Subscribe
- Permalink
