- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware Check Error
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using the app, and unable to update my firmware. Bought the router new 6 mos ago, and haven't been able to run an update, so I'm still on 1.02.46. Any advice on how to get the update functioning? I get a "firmware check error" each time.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updates are always recommended over a wired connection using the WebGUI at http://192.168.1.1 - do not use crappy apps and certainnly no wifi either. Firmware updates are delicate processes. The tiniest interruption and you end up with a bricked router
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware Check Error
Apologies. Found the manual, followed the instructions. updated via web. no idea why the app won't work, but atleast im updated now!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just FYI. The app update process is a good way to soft brick the router. Then have to go through the pain of a tftp process so do not do it.
Best way, is read the user manual and do a manual update which is connect a PC/MAC to the router via Ethernet connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
May I ask what a 'bricked' router is? I see that note all over the forum, and not sure what that exactly refers to, other than it's obviously not good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
A bricked router is one that has gone through a failed firmware upgrade and won't operate anymore as it should. Depending on how it got bricked (what actually happened), it'll either go into a boot-loop (start over and over again) or it will just go "dead" and not respond to anything any more. A bricked router can be usually recovered using TFTP flashing but in some cases you may need to open it up and connect to serial line to de-brick it
