Reply
Firmware Update 1.0.2.74
RealDogfart
Guide
I updated the firmware from 1.0.2.68 to the 1.02.74 using the Netgear App and after complete the router cycles a reboot about every hour.  Going to try a hard boot and if that doesn't work I'll try a rollback.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 8
Guru
Re: Firmware Update 1.0.2.74
Before the roll back,I'd actually try reinstalling the firmware over a hardwired connection. We tend to see the most issues/problems stemming from people updating firmware via the app or over wireless.
Try that with the factory reset and if it doesnt' help, then try the downgrade.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 8
RealDogfart
Guide
Yeah, that's a good idea.  I don't know why 'I' didn't think of it!  Thanks.
Message 3 of 8
Guru
Let us know how it goes!
Message 4 of 8
RealDogfart
Guide
Well, I tried updating the firmware again, this time from a lan / browser. No change. So I rolled it back. When I find time I'll try again.
Message 5 of 8
trdgfdgf75
its the same problem that i am facing in my laptop i dont know how to find its solution thats why i am here can some one help me to continuo my project.
Message 6 of 8
Guru
@trdgfdgf75 did you read through the thread?
If so and the solution doesn't work for you, start your own thread and we'd be happy to help
Message 7 of 8
RealDogfart
Guide
For the record, I was never able to get the update to work. I tried several times each with a different approach. It looks like a new firmware update (V1.0.2.78) is available... I'll give that one a try to see if I get better results.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 584 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
