- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware Update Failure Nighthawk AC1900 R6900
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been unable to update the firmware today. Signing in to the network going to ADVANCED > ADMINISTRATION > ROUTER UPDATE it says I'm currently at 1.0.1.26 and should be at 1.0.2.16_10. I click the download button and it says ROUTER DOWNLOADING but quickly follows with FAILED TO UPDATE FIRMWARE. Any help would be appreciated. I'm not having any particular problems other than slower than molasses internet speed that probably is the fault of my ISP. Maybe I should let well enough alone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Firmware Update Failure Nighthawk AC1900 R6900
You may need to try a manual update here is a KB on how to do that.
https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply DarrenM. This is EXACTLY how I attempted to update the firmware, ethernet connection and all. It wouldn't work for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are trying to jump near on 10 firmware versions. That's three years' worth.
It might help to try an intermediate version or two. Sometimes Netgear puts out "severe" upgrades that change things so much that you need to retrace your steps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, that does make sense. I will go at it from that angle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good luck.
There are also times when Netgear advises a reset and/or reboot before the upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you mean that little hole on the back of the router? Would that reset my password?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Return the Router to Its Factory Default Settings.
