Reply
Firmware for R7000 download
j_n
I want to update the firmware on my R7000 router.  I downloaded version V1.0.11.110_10.2.100.zip  When I try to unzip the file, Windows reports failure - the folder is empty.  Windows also reports the file to be 29.033 KB  What am I doing wrong?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 5
Guru
Re: Firmware for R7000 download
I just tried downloading it and extracting it and it came out fine.
https://www.netgear.com/support/product/R7000#download
Do you have a different device or browser to try?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 5
antinode
Guru
> [...] When I try to unzip the file, Windows reports failure - the
> folder is empty. [...]
   "try to unzip the file" _how_, exactly?  Right-click on the zip
archive file (in File Explorer), and select "Extract all..." to extract
the files in the zip archive.
> [...] Windows also reports the file to be 29.033 KB [...]
   Plausible.  The exact size is 29729578 bytes.  (And 29729578/1024
rounds to 29033.)
> [...] What am I doing wrong?
   What, exactly, are you doing?
Message 3 of 5
j_n
Message 4 of 5
j_n
I am doing exactly what I have done many times before.  I right click on the .zip file and then select unzip from the resulting window.  Windows 10 responds with the folder is empty.unzip.jpg
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 462 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
