Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Firmware update - Nighthawk MR60
ljcrompton
Hello,
I have had an email from Netgear telling me there is a new firmware update for my Nighthawk MR60 however when I go into the Nighthawk app to check for updates it says there are no updates available.
Any ideas?
I’m currently on Firmware version V1.1.6.122 however I believe the new version is 124.
How do I force through this update?
Message 1 of 3
Re: Firmware update - Nighthawk MR60
@ljcrompton wrote:
Hello,
The on-board check for new firmware is unreliable. It can miss updates, especially when you are a long way behind the latest. It can also be a while before updates hit the automated update servers.
The best way to check is to visit the support pages for your device and to look at the library of available updates.
Support | NETGEAR
Feed in your model number and look for firmware for your device.
The release notes should also tell you how to manually update the firmware.
MR60 / MS60 Firmware Version 1.1.6.124 | Answer | NETGEAR Support
Or read this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Message 2 of 3
ljcrompton
Thanks Michael
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 817 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
