- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware update error
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am trying to update my firmware and I keep getting an error stating that it is unable to download the language file. I've tried downloading the firmware update directly, but the version on your website is a lot older than what's already installed on my router. What can I do to update my firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Firmware update error
There's 2 versions of the R6400. Which version do you have?
Which version are you on?
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hopefully you are not using an app to do the update. Good way to brick router especially when you are having problems. Manual update where you Ethernet connect to router is safer. Described how to when you download the firmware or in the user manual from the same site. Go to this site and put in your router model. Will be taken to location where firmware is and also user manual. Not sure why Netgear makes this hard to find.
https://www.netgear.com/support/download/default.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
and which version are you currently on?
Are you selecting v2 from the drop down when you go to your support site?
https://www.netgear.com/support/product/R6400v2.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Occassionally the backend server gets updates before they're loaded to the website. Usually you don't see it go from 1.0.4.* to 1.0.6*. If you're on something newer, then you're on the most recent firmware. (if you truly are on the R6400v2 with that version firmware)
