Orbi WiFi 7 RBE973
Reply
Firmware update is reliable
weber2333
Follower
Which firmware is more reliable for my x6 3000 wifi router. The old version or the newest version. When I’m on the new version my speed drops tremendously. I’ve already reset router and spectrum modem.
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 3
Accepted Solutions
No1Mportnt
Luminary
Re: Firmware update is reliable
Definitely stay with the older one because there are issues with the latest update. I have that router and when I updated the readyshare functionality stopped working.
Message 3 of 3
All Replies
Guru
If the newer one causes issues, then I'd stick with the older one.
When you upgraded, did you do a factory reset and a clean install? (not from backup)
Message 2 of 3
No1Mportnt
Luminary
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 582 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
