Reply
Firmware update
RetiredNuke
Firmware update
So, a firmware "update", and now errors.  Great job, Netgear, do ya'll even test this stuff before you put it out?
Uncaught ReferenceError: start_cycle is not defined
Message 1 of 6
IrvSp
Master
Re: Firmware update
Would it be too much trouble to give details if you want help or did you come here to **bleep** to the other users here? Need help, supply simple details, like router modem, firmware you installed, and may be screenshot or two. Want to go after NG, go to the SUPPORT tab, sign-in and then MY SUPPORT and open a case.
If you have the XR700, look here, http://forum.netduma.com/topic/27477-uncaught-referenceerror-start_cycle-is-not-defined/.
Message 2 of 6
RetiredNuke
Re: Firmware update
The error is listed, what other detail do you need? Oh, the model number? Would have put it in there, but it isn't listed.....
Message 3 of 6
RetiredNuke
Re: Firmware update
And, tried to open a case, but also does not seen to be an option. Did I ask for your opinion anyway?
Message 4 of 6
DarrenM
Sr. NETGEAR Moderator
Re: Firmware update
What router model do you have and can you provide a little more detail on what issues you are having.
DarrenM
Message 5 of 6
Re: Firmware update
That is often a sign that someone is posting in the wrong section.
For example, if it really is the XR700 try here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 915 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
