Reply
Highlighted
Follower
Firmware v1.0.2.6 causing issues with my R6700
After the update Netgear Genie no longer recognizes my router, and my wifi is dead, I am however able to use my ethernet connections for now. and I can't even connect through my browser using ther router's IP.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Highlighted
Guru
Re: Firmware v1.0.2.6 causing issues with my R6700
   What do its LED indicators indicate?
   If you have the typical flashing Power indicator, then you may be a
candidate for the TFTP recovery scheme.  See, for example:
      https://community.netgear.com/t5/x/x/m-p/1622096
   Otherwise, you might start with a settings reset.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Factory Settings"
(or "reset").
   Restoring old saved settings could restore the old problem(s), too,
so a manual reconfiguration will be required after the reset.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 308 views
  • 0 kudos
  • 2 in conversation
Announcements
