Reply
Fix OPENVPN
96708
Apprentice
Fix OPENVPN
We have not heard s nor has there been any action from NG on fixing it. OpenVPN says the grace period will end soon where none of use will even be able to use OpenVPN unless NG updates its software. I swear to god if NG does not fix this BS you will read about it in the newspapers and you will lose sales. F waiting foreever for a NASDAQ listed company to fix something. WTF do we need to do to get proper help? And dont f act llike this is a new problem. If you are a mod and you come her acting like that you should resign beause you dont know your own product. F this s. Fix it.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Re: Fix OPENVPN
Can you explain what the issue is? Then perhaps someone can pass it on to the powers that be in Netgear.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 4
JamesGL
Master
Re: Fix OPENVPN
Hi 96708,
NETGEAR is aware of it and is working to update the OpenVPN certificate. It will be released before the deadline.
Message 3 of 4
96708
Apprentice
Re: Fix OPENVPN
You remind the people in charge that if the deadline is not met, NG will face 1) a class action lawsuit 2) the **bleep** will hit the Wall Street Journal 3 ) New York Times and 4) all media channels to blow this out publicly to a wider audience.
Its taken well too long. Even a BBB claim against NG got some BS response about the router being out of warranty. Well, at Best Buy and other major retail channels such as Costco and Amazon, you still sell the R7000 and the packaging clearly says it supports OpenVPN. So the warranty out of date excuse is BS.
Its taken well too long. You tell CEO Patrick Lo the **bleep** is about to hit the fan and NG will be reeking of stench and lose all market share if this issue is not fixed as it should be.
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 227 views
  • 0 kudos
  • 3 in conversation
Announcements
