Reply
Functional Difference(s) Between Telstra Branded and Unbranded Nighthawk M1?
netsolutions
I live in Australia where the Telstra network uses a branded version of the Nighthawk M1. Unbranded and unlocked versions are also available from independent suppliers.
Apart from the locked or unlocked, does anyone know if there is a functional difference between the two? I am referring to frequency band compatibility and similar practical considerations.
Model: MR1100|NIGHTHAWK M1
Message 1 of 2
Re: Functional Difference(s) Between Telstra Branded and Unbranded Nighthawk M1?
You might get better responses in the appropriate section:
Mobile Routers, Hotspots & Modems - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 384 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
