Reply
GS205 Only 1 internet connection out of the 4 available, HELP!!!
LorenMc
Follower
I connect the main ethernet cable to #1 then get internet from #2 but that's it, #s 3-5 does not distribute net.
Would really appreiciate help.
Model: GS205v2|Unmanaged Switch
Message 1 of 2
antinode
Guru
Re: GS205 Only 1 internet connection out of the 4 available, HELP!!!
> I connect the main ethernet cable to #1 [...]
   From where, exactly, does your (mysterious) "the main ethernet cable"
come?
   If you're connecting some kind of modem to your network switch, then
that's the kind of result I'd expect.  If you want to connect multiple
client devices to your typical residential Internet service, then what
you need is a (NAT) router, not a network switch.
   Not every device which has multiple Ethernet ports is equivalent to
every other one.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 136 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
