Reply
Galaxy S20 R8000 wifi issues
StrossBoss
Follower
Hey all,
I have been having connectivity issues with pretty much any android phone that tries to connect to the network. First it was both my girlfriend's and my Pixel 2XL. Recently we switched to the S20 and it's the same issue. It picks up the network but fails to connect even though other devices work without issue. Sometimes it will even disappear from the list. I have to manually click connect multiple times and sometimes it finally goes through. I am wondering if it is the smart connect feature causing the issue?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Accepted Solutions
microchip8
Master
Re: Galaxy S20 R8000 wifi issues
Smart Connect on NG routers is pretty much sub-par. It is not that "smart" at all and can cause various issues. Do a test by disabling it and see if the issue goes away. Then you'll know it's Smart Connect causing it or not.
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.91SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 3
All Replies
microchip8
Master
Message 2 of 3
Kevclar
Initiate
All of the connectivity issues with my 13 devices went away when I turned smart connect off.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 699 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
