Reply
Genie took over routerlogin.net?!
TheSandman
Tutor
FRIDAY MARCH 30TH,2018
I woke up only to discover my electronic devices disconnected from the Internet
It turns out that Netgear Genie has replaced login to www.routerlogin.net
What happened?
I already thought routerlogin.net functions were too simple. But Netgear Genie is so simple, a 2 year old can understand it.
Why the change?
Where's my port forwarding options?
How can I be certain about router security, when www.routerlogin.net never had HTTPS in the first place?
Is this for real? Or am I hacked?
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 3
Re: Genie took over routerlogin.net?!
Grown ups use the brower interface.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
antinode
Guru
> www.routerlogin.net
   That is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> What happened?
   You were there.  You tell us.  With my weak psychic powers, I have no
idea what you did or what you saw.
> Why the change?
   Why _what_ change?
   Define "router security".  If you connect power and one computer (and
nothing else) to your router, then you can be pretty sure that you're
talking to your router.
   Is _what_ for real?
   You'd do everyone a favor if you reported on actual events, and
avoided reporting only your analysis of them.  A precise, accurate
description of what actually happened would be much more helpul than
what you think it all means.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 436 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
