Reply
Get a reverse DNS record
blund29
I ran the test ipv6-test and it told me I need to "Get a reverse DNS record." How do I go about this?
Message 1 of 5
antinode
Guru
Re: Get a reverse DNS record
> I ran the test ipv6-test [...]
   Why?  Should anyone know what "the test ipv6-test" means to you, or
how you "ran" it on what?  I certainly have no idea.
> [...]  and it told me I need to "Get a reverse DNS record." [...]
   Did it (whatever "it" might be) say why?  Again, a little context
might help.  Is that the actual message, of your interpretation of the
actual message?  Copy+paste is your friend.
> [...] How do I go about this?
   No idea.  Don't know what it means.  Is there some actual problem
which you are trying to solve?
   This is a Netgear forum.  Are you using some Netgear device?
Message 2 of 5
blund29
Sorry for not giving more information. Yes I am using Netgear devices. I'm am trying to fix an isssue with a game I get disconnected from. One suggestion was to use IPv6 instead of IPv4 so there is no issues with NATs. So I went about changing some settings and turning on IPv6.
I used this site http://ipv6-test.com/ before and after my changes to see if my changes worked. It seems to have worked, but lastly they suggested this:
There is no reverse DNS record to associate your IPv6 address with a host name. Reverse DNS records are required by some Internet protocols and are usually managed at the ISP level.
Message 3 of 5
Yes, but what are they?
Does the hardware support IPv6? Does your ISP support IPv6?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 5
schumaku
Guru
Commonly the end users are not the owners of the IPv6 pool assigned, so it's up to the ISP to configure a reverse DNS record. Considering the large number of IPv6 addresses in each commonly assigned prefix does make that plan almost impossible however. Unlikely the absence of a reverse DNS record isn't the cause of the game issue.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1243 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
