Reply
Giving the same name to extender network
jrl95608
Follower
If I give my extended network the same name as my router network, how do I force a device to connect to the extended network? How do I know devices that are connected to the extended network rather than the existing router network?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Guru
Re: Giving the same name to extender network
If you're using a mesh extender or just setting the ssid's the same, then you're devices are doing the roaming.
If you're wanting them seperate, then name the ssid's different.
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 97 views
  • 0 kudos
  • 2 in conversation
Announcements
