Reply
Good wired Access Point to connect to the AC3200 Model R8000.
Bumphouse
Follower
I have the AC3200 Model R8000 located on my first floor. I also have the AC2200 Model EX7500 to extend the signal throughout the house. What wired Access Point do you suggest to put at the other end of my house, in the basement. I plan to use ethernet connections on the Access Point for better connections and speed.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Guru
Re: Good wired Access Point to connect to the AC3200 Model R8000.
That's a very loaded statment.
Its basically whatever works for you.
many of netgears products have access point mode. You could go with an extender (that has ap mode), a router, or even a business class AP. There's a ton of options.
so look at what you need for coverage, ethernet jacks, wireless specs. That at least narrows your list. And then you choose from one of those devices.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 139 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
