Reply
Google Assistant and router control not working as expected
Thanatoast
Follower
I have a Nighthawk R7960 (AC3600) which I am trying to get to work with Google Assistant.
I have linked Netgear and Google and I can control the router by giving commands that start with "OK Google tell Netgear..." (OK Google tell Netgear to turn off guest network)
What I want to be able to do is control it as described here by Netgear:
https://kb.netgear.com/000049504/Which-Google-Assistant-commands-does-my-NETGEAR-router-support
Without having to "tell Netgear."
Any ideas on how to get this to work right?
Thank you
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Google Assistant and router control not working as expected
I will have to check to see if that KB is correct or needs to be updated.
DarrenM
Message 2 of 3
DarrenM
The KB was wrong you do have to say Tell Netgear or Ask Netgear to use these features. Very sorry about that the KB will be updated.
Thanks
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 288 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
