minime701
Oct 29, 2017Follower
Google Home Mini Connectivity Issues with Netgear Nighthawk
Hi, I'm trying to connect my Google Home Mini to my Netgear Nighthawk AC1900. However, it doesn't connect. When I look on the Google Support page for connectivity issues it says:
Netgear Nighthawk router and Google Home
If you're having trouble setting up Google Home using the Netgear Nighthawk router, particularly model R7000, try:
- Disabling Access Control
- Enabling the option "Allow guests to see each other and access my local network" in the "Guest Network Setup"
May someone please tell me how to do this? I tried disabling Access Control on routerlogin.net , and the option for "allowing guests" is already enabled. However, my Google Mini still doesn't connect to the router. Can someone give me a guide (pictures would be nice) in fixing this.
Thanks
Hi minime701,
Please check what security type Google Home Mini supports.
You can try to change channels as well for your wireless network.
- JamesGLNETGEAR Employee Retired
Hi minime701,
Hi minime701,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
