Reply
Guest network
MandyBear
Follower
Guest network
I have model #R6350 and I am not able to locate the guest network so I can have my PC run on it while other things use the other network. Can someone please help me figure out how to locate the Guest Network? It is NOT showing up on any of my other devices either. Thanks in advance
Model: R6300v2|AC1750 Dual Band Gigabit router
Message 1 of 3
schumaku
Guru
Re: Guest network
Assuming you talk of the R6350 - please consult the R6350 User Manual, p. 57 ff. starting from "Manage the Basic WiFi Settings and WiFi Security of the Guest Network" for enabling and configuring the guest network. Be aware that the initial config will set an "insecure" and fully open guest WiFi in place - you might want to add some security as explained.
Message 2 of 3
antinode
Guru
Re: Guest network
> [...] locate the guest network so I can have my PC run on it while
> other things use the other network. [...]
   What benefit are you expecting to gain from using the guest network
for your own "my PC"?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 259 views
  • 0 kudos
  • 3 in conversation
Announcements
