Discussion stats
  • 4 replies
  • 2550 views
  • 1 kudo
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
HP 6830 Red Port light and offline
My printer is connected to the R7800 via ethernet cable and the port(3) light is Red. I've tried changing cables and ports with the same result. When accessing the port 192.168.1.14 thru the HP Status page ob my cimputer it shows Connected and no problems. My computer is also Wired into the router withoiut any problems.
I've resinstalled the printer software and my problem remains
Any help is appreciated. Thanks
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 5
Accepted Solutions
Highlighted
NETGEAR Employee Retired
Re: HP 6830 Red Port light and offline
Just a quick note, if it's amber it means that the device plugged in is not maximizing the speed that the router can offer which is up to 1Gbps.
Perhaps, the printer is only capable of up to 100Mbps. You may check this from the LAN specification of the printer.
ElaineM
NETGEAR Community Team
Message 3 of 5
All Replies
Highlighted
Please cancel this post. A friend told me the light is Amber-not red. Sorry
Will look for other answers
Message 2 of 5
Highlighted
ElaineM
Message 3 of 5
Highlighted
Thank you for the information. Will look into it.
Message 4 of 5
Highlighted
You're welcome!
ElaineM
Message 5 of 5
