DillRiLi
Jan 04, 2022Follower
Hacked
Today when I logged on to my computer there was a problem with the Netgear Extender. I clicked on a prompt to resolve the problem which lead to a Netgear assistant that asked if I needed help setting up my Extender. I typed in "Yes" and they asked if they would like to have someone call me to help with the setup process. I typed in "Yes" and someone claiming to be from Netgear called me and proceeded to ask questions about the model number of the Extender, the router I was using, etc. He then said he would like to help with the setup of the Extender and asked to gain access to my computer to complete the setup. After some time, I reluctantantly agreed. After connecting to my computer, he then proceeded to tell me there was a network security issue and that I would need to consider purchasing "Network Firewall Security Basic" from Cisco. He said this could not be purchased through Netgear, but I should consider contacting a network connection specialist to obtain IP protection. I told him okay and unplugged my Extenders and my router. I then called my internet service provider (AT&T) and after some time and effort communicating what had happened they indicated that the communication with what I thought was Netgear was actually flauduent. They also indicated that this is not the first time they have heard of this. I changed passwords and such to secure my computer. I still have the number of the guy that said he was from Netgear.
I tried to contact Netgear with this issue directly, but could find no direct email. What a joke. This was the best I could do to communictate this issue in the hopes that it helps someone, or Netgear identifies the hack.
1 Reply
Netgear has set up a community forum specifically for the WiFi Extender products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
