Reply
Have a Gigabit Network Card Still Amber light
marcdjr
I have an Asus G53JW which I believe has a gigabit network card.
I still only get an amber light when plugged into the router.
Ideas as to why this is?
Thanks!
Message 1 of 6
jmizoguchi
Virtuoso
Re: Have a Gigabit Network Card Still Amber light
Try update the driver for the NIC
If still the same try to force the NIC to got 1000Base-T/Full Duplex instead to Auto Negotiation under network updater setting on PC side
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 6
Retired_Member
Not applicable
Try another cable too.
Message 3 of 6
Retired_Member
Not applicable
Trying to hard set speed/duplex might causes more issues, honestly.
Autonegotiation is part of the 1000bTX standard.
Update NIC drivers, try a different cable, both good suggestions.
Message 4 of 6
marcdjr
Should have tried the simplest first.
Tried factory reset, NIC driver update, and finally it was the cable.
Thanks!
Message 5 of 6
Retired_Member
Not applicable
cut it in half before you forget and use it again
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2575 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
