Reply
Having trouble finding driver info for my Nighthawk R6700v3
Uncommongrain93
I am currently working on a network extender for a college project. The tutorial that I am using asks to ensure that when setting up the Raspbery PI to the "wlan" device to make sure the correct drivers are known. I do not know what drivers I have for this device (the wlan I presume). I have looked through the user manual and many other sources and found nothing, I'd appricate some help!
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
antinode
Guru
Re: Having trouble finding driver info for my Nighthawk R6700v3
> [...] The tutorial that I am using [...]
   With my weak psychic powers, I can't see it from here.
> [...] asks to ensure that when setting up the Raspbery PI to the
> "wlan" device to make sure the correct drivers are known. [...]
   That sounds to me like a Raspberry Pi question, not anything to do
with any router.  Which OS are you using on the R-Pi?  That's where any
relevant device drivers would reside.
Message 2 of 4
Uncommongrain93
This is the step where it asked for the drivers, It says "best driver for your device so I'm guessing that thats for the router not the PI.
Message 3 of 4
antinode
Guru
> This is the step where it asked for the drivers, [...]
   In-line images must be approved by a moderator before others can see
them.  The time required varies. Attachments have no such limitation.
Of course, attachments have their own one-per-message limitation.
   A link to the real thing might be more helpful, in any case.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 160 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
